Integrated
Bindery Systems
British Engineering logo
Link to IBIS LinkedIn page
Exam Booklet Production
Using the IBIS Smart-binder
Exam booklet production PDF data sheet View case studies
The Smart-binder is the premium saddle-binding solution for production of examination booklets from digital printed sheets:
Typical Exam Booklet Production Lines
Nearline production of exam booklets
IBIS Smart-binder
Web-cutter
Roll-unwinder
Near-line, fed from a web-cutter
Inline production of exam booklets
IBIS Smart-binder
Web-cutter
Digital print engines
In-line, fed from a digital printer and a web-cutter
View Videos
The Dubai 2025 video includes stacking, wrapping and labelling.
SB producing exam papers, Dubai 2025 Video: Stacking wrapping & labelling SB producing exam papers in‑line SB producing 16pp A4 exam papers
Why use the IBIS Smart-binder
More printing companies are using IBIS Smart-binders to produce exam booklets compared with any other digital finishing system. The reasons for this are as follows:
1. Booklet security and integrity
The highest priorities for exam booklet production are security and page integrity. Security is needed to ensure that there is no breach of printed examination booklet data. Finishing in-line with the printer is often preferred because then printed sheets or rolls do not need to be stored prior to stitching: they are finished directly into booklets. Finished booklets are often immediately stacked, strapped and/or wrapped so that the printed data cannot be viewed by anyone until the pile bundles are unwrapped in the examination test location.
It is essential that no sheet can mistakenly end up in the wrong examination booklet resulting in one student with a page missing and another with an additional incorrect page - not the best start for a successful exam result for those individuals!
For this reason the Smart-binder has a fully integrated sheet detection and tracking system (using a bar code printed on each sheet) to ensure the integrity of each finished booklet. If there is any risk that a booklet could have incorrect pages, or the correct pages in the wrong sequence, then it is automatically rejected.
Examination booklets made by IBIS Smart-binders
Examples of examination booklets made by IBIS Smart-binders at different customer sites around the world.
2. High reliability with minimum maintenance
Machine 'availability' (up-time) is important in a high volume exam booklet production environment, particularly when operating in-line with a digital web printer. The Smart-binder is a very heavy-duty system designed to operate 24/7 with the minimum of maintenance and with the highest possibility reliability. Some IBIS Smart-binders have produced over 70 million examination booklets.
3. High speed output
Exam booklets normally contain a small number of pages which means a high cycling rate if running inline with a high speed digital printer. The Smart-binder can therefore run constantly at web speeds around 100- 150 meters/minute and typically producing around 7,000 A4 booklets/hour when making 8 - 16 page booklets
4. Stacking, strapping, wrapping and labelling
The optional Booklet Stacker  BSS-10 is often used when making examination booklets when they contain a small number of pages because of the resulting high production and also because it is desirable to reduce the number of operator contact points and the number of opportunities for the printed data to be visible.
BSS-10 book stacker
Book entry from Smart-binder delivery
Book stack delivery
BSS-10 book stacker
For this latter reason the stacked booklet piles are often then immediately in-line strapped (to avoid the booklets being removed and opened) and also sometimes fully wrapped. Printed labels may need to be added at this stage to identify the school and/or the specific exam for which the booklet stack is intended.
5. Variable page extents
Sometimes the run lengths for exam booklets can be very low, even though the daily volumes can be very high. e.g. 1 million exam booklets a month from each Smart-binder. The Smart-binder can change the number of pages 'on-the-run' under bar-code control, while maintaining the integrity in each individual booklet (correct pages in the correct sequence).
6. Cover matching
A separately-printed cover sheet, if needed, may be fed from the optional Smart-binder cover feeder. If personalized then the cover may be bar coded so the Smart-binder can ensure it is correct one for the booklet to which it is attached (note: examination booklets do not normally require a separately fed outside cover sheet).
7. Document personalization, question shuffling and booklet tracking/reprint
Exam booklets may be personalized and may include the student's name. Consecutive booklets may include the same questions but in a different sequence to reduce risk of the student copying from their neighbor during the exam process. This is sometimes called 'question shuffling'.
Data tracking is often essential in order to know exactly which exam booklets have been produced and to allow any missing/rejected booklets to be reprinted. The Smart-binder includes a sophisticated tracking system using Bar code (or Datamatrix) code readers and sensors. The Smart-binder control PC retains log files containing production data relating to each booklet that has been produced or rejected. The production log files may be viewed externally with a network connection if required. The optional SDA-100 Smart-Data Analysis system assists with the upstream interface to enable automatic reprinting of any missing booklets
8. Answer sheets and automated marking
Exam question booklets may need to include a detachable 'answer sheet'. The webpage Add answer sheets to exam booklets describes the five different ways that answer sheets can be added to exam booklets when printing with the Smart-binder.
Automatic 'matching' is then provided to ensure that each booklet contains the correct answer sheet
Automatic 'marking' of completed 'multiple choice' examinations may require the spine of the booklet to be slit off so that the pages can then be fed individually thought an automatic marking machine. Alternatively it may be the completed multiple-choice answer sheet itself which is removed from the booklet for processing by the marking machine.
9. Wire stitching or ISG cold gluing
IBIS's unique and patented ISG Cold Glue system provides a higher quality binding alternative to wire stitching. This results in improved booklet lay-flat which can help subsequent inserting and mailing operations.
Smart-binder 'Plus HS' input and output
Exam booklet
delivery (to optional
BSS stacker)
Printed
sheet
entry
IBIS Smart-binder 'Plus HS
View the IBIS Smart-binder system in operation on our website.
View a video of the Smart-binder SB-2 producing 16pp A4 exam booklets in-line with Canon Colorstream 6000 series printer at 100 metres/min web.
IBIS In-line Wrapping Solutions for Secure Exam Booklet Production
IBIS specializes in providing customized in-line booklet wrapping solutions to ensure the highest possible security for examination test booklet production
Smart-binder 'Plus HS' with BSS-10 stacker, pile banding and wrapping
For more information on Exam Booklet Wrapping please follow the links below.
Wrapping Overview
Optional modules available
Typical floorplan layouts
Requirements Questionnaire
Case Studies
View Case Studies of customers that are using the IBIS Smart-binder exclusively to produce exam booklets:
